Dear Independent Operator,
Ford Motor Company Limited will be in due course implementing a mandatory Global Online system called Global Ford Dealer and Repair System (Global FDRS) and existing FordEtis FDRS Online Applications will no longer be available.
However, in preparation of the Global FDRS switch on, Ford Motor Company Ltd is requesting that all independent operators download and install the Global FDRS software application onto their computer’s prior to the 29th September 2019 by following the instructions set out in the document available for download at https://www.etisload.ford.com/EtisGFDRS ... sGuide.pdf.
Global FDRS switch on date will be the subject of a subsequent email.
Charges
Charging of the Global FDRS system, you will be able to purchase a 48-hour, 1-month and an Annual License. The Global FDRS license will incorporate a Ford IDS License, access to FordEtis online Technical Literature i.e. mechanical repairs, Wiring diagrams etc. and Global FDRS Applications for unlimited Vehicle Identification Number’s (VIN’s) entered for the Global FDRS License purchased.
Notes:
There will be no additional charging for FordEtis Online technical Literature and FDRS applications.
EU5 Accreditation Security Access
Independent Operators that already have EU5 Security Accreditation Access will be unaffected by the switch over and will be able to use Global FDRS.
Independent Operators that wish to purchase EU5 Security Accreditation Access, to be able to use Global FDRS for key programming and certain module security applications within Global FDRS can do so by contacting the Ford IDS helpdesk at the following email addresses:
United Kingdom: [email protected]
Germany: [email protected]
Rest of Europe: [email protected]
Independent Operators without an Active Ford IDS License
Please review the process document available for download at https://www.etisload.ford.com/EtisGFDRS ... sGuide.pdf on how to set up, purchase licenses and use Global FDRS.
Independent Operators with an Active Ford IDS License
Existing Users that have purchased an Annual Ford IDS License Activation code, (via the FordEtis Online Application) from Ford of Europe will be able to use Global FDRS with their existing Ford IDS License until it expires. Once it expires, you will be able to purchase either a 48-hour, 1-month and annual Global FDRS License.
Independent operators that have purchased their Ford IDS License Activation Code via another supplier/company other than Ford of Europe will be prompted to purchase a 48-hour, 1-month or an Annual License to be able to use the Global FDRS Application.
Regards
Ford ETIS wird abgeschaltet/ersetzt
- Postleitzahl: 46499
- Echtname: Ronny
- Danksagung erhalten: 97 Mal
Das kam heute per Mail:
Und auch ETIS wird in Kürze abgeschaltet
eMail bekommen:
"Sehr geehrter unabhängiger Betreiber,
Ford Motor Company Limited wird zu gegebener Zeit ein verbindliches globales Online-System implementieren, das als globales Ford-Händler- und Reparatursystem (Global FDRS) bezeichnet wird, und vorhandene FordEtis-FDRS-Online-Anwendungen werden nicht mehr verfügbar sein.
Zur Vorbereitung des Einschaltens von Global FDRS fordert Ford Motor Company Ltd jedoch alle unabhängigen Betreiber auf, die Global FDRS-Softwareanwendung vor dem 29. September 2019 auf ihren Computern herunterzuladen und zu installieren, indem sie die Anweisungen in dem zum Herunterladen verfügbaren Dokument befolgen unter https://www.etisload.ford.com/EtisGFDRS ... sGuide.pdf.
Das globale Einschaltdatum für FDRS ist der Betreff einer nachfolgenden E-Mail.
Gebühren
Wenn Sie das Global FDRS-System aufladen, können Sie eine 48-Stunden-, 1-Monats- und eine Jahreslizenz erwerben. Die Global FDRS-Lizenz beinhaltet eine Ford IDS-Lizenz, Zugriff auf die FordEtis-Online-Fachliteratur, d. H. Mechanische Reparaturen, Schaltpläne usw., und Global FDRS-Anwendungen für unbegrenzte Fahrzeugidentifikationsnummern (VINs), die für die erworbene Global FDRS-Lizenz eingegeben wurden.
Anmerkungen:
Für FordEtis Online Technical Literature- und FDRS-Anwendungen fallen keine zusätzlichen Gebühren an.
Zugang zur EU5-Akkreditierungssicherheit
Unabhängige Betreiber, die bereits über einen Zugang zur EU5-Sicherheitsakkreditierung verfügen, sind von der Umstellung nicht betroffen und können Global FDRS verwenden."
Google- Translate weil ich zu faul bin:Ford Motor Company Limited will be in due course implementing a mandatory Global Online system called Global Ford Dealer and Repair System (Global FDRS) and existing FordEtis FDRS Online Applications will no longer be available.
Global FDRS switch on date will be the subject of a subsequent email."
Charges
Notes:
Gebühren
Anmerkungen:
- Hat sich bedankt: 557 Mal
Re: Ford ETIS wird abgeschaltet/ersetzt
[Anmerkung der Moderation:] Da ein Thread zu diesem durchaus wichtigen Thema ausreicht, habe ich die beiden existierenden Posts dazu mal zusammengeführt, sowie die jeweils gegenseitigen Verweise aufeinander entfernt, da sie obsolet geworden sind.
So, und jetzt viel Spaß beim diskutieren.
Und wieder gibt es "Neuigkeiten":
Zumindest ein Großteil von 2021 scheint ja noch gesichert zu sein.
Bin gespannt, a): wie lange wir da noch drauf zugreifen können und b): ob wir dann auch auf das neue System drauf kommen.Betreff: FordEtis: Regarding FordEtis Online Migration to Ford SERVICE Info Site Online
Datum: 2021-02-01T13:30:50+0100
Von: "FordEtis Business Team" <[email protected]>
An: "[email protected]" <[email protected]>
To all Independent Operators and FordEtis Users: Regarding FordEtis Online Migration to Ford SERVICE Info Site Online.
Dear FordEtis User,
FordEtis Online and its users will be migrating to a new online Ford SERVICE Info site during 2021.
The migration to the new site will take place in February 2021 and will provide Independent operators, once registered, options to purchase Ford Diagnosis and Repair System (FDRS) and Technical License subscriptions to use with the Professional Technician System (PTS) site for the new Ford Mach E vehicle content.
All other FordEtis vehicle content will gradually be migrated to the new site throughout the course of 2021.
During the migration phase, FordEtis users will still be able to purchase and access subscriptions for FordEtis online, Ford Diagnosis and Repair System (FDRS) including IDS providing a valid FordEtis/FDRS subscription has been purchased.
Note: This does not affect users of the WLTP calculation tool. All WLTP calculations will continue to operate in FordEtis until further notice.
Please note this is the first of a series of communications we are emailing, and in due course Ford will keep you updated on the migration to the Ford SERVICE Info website.
Regards
Ford Motor Company
- TKS
- Mustang: 2020 GT Fastback
- Sonstiges: ¯\_(ツ)_/¯
- Hat sich bedankt: 115 Mal
Genau, Apfel- und Linux-Benutzer braucht man nichtFord Service: "Run GFDRS.exe and follow on screen install instructions."
"Beim Beschleunigen müssen die Tränen der Ergriffenheit waagerecht zum Ohr hin abfließen." (Walter Röhrl)
- dtmdriver
- Postleitzahl: 79639
- Echtname: Matthias
Honda Fireblade SC59 ABS
Kawasaki Z900
Ford Fiesta ST MP215
Toyota Avensis 2.0 - Hat sich bedankt: 1981 Mal
Warum auch, wird im Betriebsumfeld praktisch keiner benutzen
Dtmdrivers Eleanor
- Pouakai
- Postleitzahl: 81xxx
- Sonstiges: 10-Gang-Automatikgetriebe
- Hat sich bedankt: 13 Mal
- Danksagung erhalten: 41 Mal
wine GFDRS.exe
Happiness is not a destination - It's a way of life.
- Tomeck
- Postleitzahl: 67316
- Echtname: Thomas Eckl
BMR
Spoiler
Hentzschel EVO 2++
305+325/30 auf 10.5+11x19 " - Hat sich bedankt: 2593 Mal
@hdgram
Hallo Dieter,
weißt du ob es für ETIS schon Ersatz?
Ich würde gerne einmal nachschauen, ob es bei mir diverse Updates für die Software gibt.
Thomas
Hallo Dieter,
Thomas
BMR: CB006/CB763/STB760
uvm.
uvm.
https://www.fordserviceinfo.com/
Aber da kommst Du nicht mehr so ohne weiteres rein.
Und das: ist auch nicht von Pappe.
Was anderes kenne ich nicht und das war die offizielle Verlinkung auf ETIS vor Abschaltung.
