Steeda S550 Mustang Rear IRS Subframe Support Braces
Offizielle Bezeichnung:
Hersteller: Steeda
Gebraucht: ja (etwa 1000 km eingebaut)
Preis: 180 Euro
VHB oder Festpreis: Fest
Weitere Transaktionsbedingungen: Da ein anderer Käufer leider abspringen musste verkaufe ich mein Steeda S550 Mustang Rear IRS Subframe Support Braces. Etwas 1000 km verbaut und damit wie neu!
With the release of the new S550 Mustang, Steeda knew that addressing the IRS system would be a top priority. Being the first production Mustang with an IRS since the 03/04 Cobra’s, we knew there would be a great opportunity to capitalise on Ford’s new piece by giving it the Steeda advantage. As with any suspension system, deflection is an issue if it’s present. Anytime a piece is moving, twisting or vibrating when it should be stationary is a major problem. One of the areas team Steeda wanted to focus on was the rear IRS sub frame.
As you have seen with our IRS Sub frame Bushing Support System, it limits the movement of the sub frame by filling in the voids of the OE bushings. With Steeda’s IRS Sub frame Support Braces, we have taken the S550 Mustang rear suspension to another level!
Our Steeda S550 Mustang Rear IRS Sub frame Braces for 2015 Mustang GT and EcoBoost (non-convertible) is built in-house from 4130 chrome moly steel and powder coated silver metal flake, this part isn’t only strong - it also looks great under your new Mustang! What we did was tie together 3 very important points on the S550 chassis. We utilised existing threaded holes in the rocker panel (the strongest part of the body) and connected that to the front mounting location of the IRS sub frame and the rear mount of the lower control arm and toe link. Connecting these 3 points together not only adds rigidity that was lacking in the rear, but also more control of the whole car.
Also, unlike competitors kits that only replace the factory bracket, our Steeda kit supports that bracket while connecting to 2 additional locations, therefore providing twice the support! Best part about this kit is it uses all existing holes in the chassis so the car doesn’t have to be modified in any way and adds no NVH whatsoever.
Product Benefits
Better handling for more stable cornering
Limits IRS sub frame movement
No permanent modifications necessary
No added NVH
50% more connecting points
Reduces wheel hop
Fully compatible with Steeda's popular Jacking Rails
Lifetime warranty
Normally in stock in the UK
Verkauft! Steeda S550 Mustang Rear IRS Subframe Support Braces
- Fennek
- Postleitzahl: 21354
C63 AMG T-Modell S205
Selenitgrau
Zuletzt geändert von Fennek am 6. Mär 2019, 10:00, insgesamt 1-mal geändert.
